Pre paid gas not working after running out
Heres a pi
Can you post a phot of gas meter from a bit further back? It looks like an upso/opso setup, which may be the issue.
Here you go.
What do you do to reset the boiler ,and exactly what happens after reset ?
Find your filling loop to top up boiler pressure
Just press the top left button is that right?
The green light flashes and the yellow goes on and off several times then the red light comes on and the error code comes up.
Your boiler isn't igniting because you either have no gas to it ,or there is an internal fault within the boiler ,if the latter it would be Quite a coincidence that you ran out of gas. How long have you lived in the property ?
Have you ran out of gas before, if so what have you done differently this time ?
Yes this is what I thought that it must be something simple. Ive only lived here about a year. When I first moved in I had the same issue with error F28 and F29. Tried everything and had to eventually call someone out. Guy took about 20 seconds in the boiler and it was working. No idea what he did. Figured it cant be anything too complicated.
How many times have you reset the boiler ? Press the reset button,and keep it depressed for 3 seconds. If it doesn't light ,try again . If still no joy ,time to call in the guy again !
Tried it loadsa times hoping it will decide to work again. Will try pressing for 3 seconds.
Unfortunately I cant afford to call anyone out right now so Im hoping I can sort it out nyself.
If it is rented property, it will likely be your landlord's problem to sort it out..
