How would you fix it to the wall?Never use normal plasterboard on external walls as there is a potential for damp which can lead to mould, you need Foil backed plasterboard!
True but the OP is insulating a wall between two heated internal spaces, so the main risk is of wasting expensive materialsYes quite. They will be thermal bridge with or without the strips and the strips are still just as useful. And cheaper than wood ones.
Lol, I know that Woods. It doesn't make the plasterboard strip any less useful in this instance.But not with an air gap or insulation strip.
I get that, but Woods was trying to argue against the merits of a plasterboard strip v's other materials - which was a bit silly in this instance (see post #9). Then started on about cold bridge from the studs - which would occur (in another scenario) regardless. And then tells the forum that another layer of insulation (across studs) would prevent this - no schitt Isambard.True but the OP is insulating a wall between two heated internal spaces, so the main risk is of wasting expensive materials
other than the plasterboard packing strips it all sounds a bit of a bodge to be honest.
Run a bead of foam adhesive down the wood first. Screw to level. Let foam go off. Nip up if necessary - but probably not. Sorted.
yes my dad did think of this but i can see the foam expanding to say 20mm and then needing to be shaved, so not entirely sure it's a better option as the thickness of the foam cannot be controlled.
Au contriare. See post #6I get that, but Woods was trying to argue against the merits of a plasterboard strip v's other materials - which was a bit silly in this instance (see post #9)
