Just had a new boiler fitted, my only concern is that the boiler inlet pipe work is not insulated, it is too hot to touch, therefore I would have thought exposed pipework of this temperature should be insulated for safety reasons. But also not insulating this pipework will result in at least a 2oC drop in return temperature, possibly higher, to the boiler. I asked the engineer and said he it’s not required. But I have to disagree, in the summer months when the boiler is heating hot water only, the heat produced from this pipe work is 100% wasted and would introduce unwanted heat into the room.
For the amount it costs, IMO this should definitely be insulated.
Won’t be able to use foam for the pipe work underneath the boiler as there’s not enough clearance, is hessian wrap ok ?
