yes, and that's not what an Owl is for.
They are an instrument for monitoring current consumption and indicating that to the owner. So what have I missed?
100% accurate
Current consumption does not indicate watts. You also need to measure volts and phase angle. The last is important and no clip on device does this. In my opinion Owls are not fit for purpose and should be banned under Consumer Rights Act.They are an instrument for monitoring current consumption and indicating that to the owner. So what have I missed?
That's a bit harsh- before smart meters with their remote display they were very handy for spotting unexplained consumption (leaving the garage lights, immersion heater, outside lights on, fridge/freezer compressor running continually, that sort of thing). For the reasons you quoted, no use for accurate billing info thoughCurrent consumption does not indicate watts. You also need to measure volts and phase angle. The last is important and no clip on device does this. In my opinion Owls are not fit for purpose and should be banned under Consumer Rights Act.
That's a bit harsh- before smart meters with their remote display they were very handy for spotting unexplained consumption (leaving the garage lights, immersion heater, outside lights on, fridge/freezer compressor running continually, that sort of thing). For the reasons you quoted, no use for accurate billing info though![]()
As I have previously illustrated, once I had established an appropriate 'average voltage' and 'average PF' to use, my OWL has proved incredibly accurate over the long-term.The Owl has a clamp meter and is not very accurate at low levels (a few hundred watts). And it only receives periodic signals. I have an idea that some loads, such as fridge and freezer compressor motors, are not very accurate. Larger, resistive loads such as heaters, are pretty good. ... It is surprisingly accurate above 1kW (try switching on a 3kW kettle or immersion heater).
You don't 'alf talk a load of rubbish.In my opinion Owls are not fit for purpose and should be banned under Consumer Rights Act.
No. You may think that but you are wrong.You don't 'alf talk a load of rubbish.
You're obviously entitled to your opinion. However, why not look at my post #22 and then tell us whether you still hold the same opinion.In my opinion Owls are not fit for purpose and should be banned under Consumer Rights Act.
They are sold as an accurate way to measure power consumption which they do not do. Goods must be fit for the purpose which the Owl is not.So what does "should be banned under Consumer Rights Act" even mean?
I asked you what "should be banned under Consumer Rights Act" means. Describe the legal procedure you will undergo to 'ban' them.They are sold as an accurate way to measure power consumption which they do not do. Goods must be fit for the purpose which the Owl is not.
I have to disagree entirely in the strongest of terms on this...They are sold as an accurate way to measure power consumption which they do not do. Goods must be fit for the purpose which the Owl is not.
John what you have done is beyond the capabilities of the average buyer.
