It may Vitiate one day it may not. Well done.
I'd be fascinated to know how you can entrain grease into a sealed bearing, perhaps you could enlighten us?There is absolutely nothing to service or adjust in my Potterton so i don't.
I grease the fan bearing every year though because Potterton thought putting the self lubricating bronze bush bearing directly above the combustion chamber was a good idea....
When i do that, i hoover out the bottom of the casing and give the rest an eyeball (esp the he/ex) but that's it
And that's as much as Potterton tell you to do tbh.
I've had it ~ 20 years so that must be close to €1.5/2k i haven't wasted.
It isn't a bearing.I'd be fascinated to know how you can entrain grease into a sealed bearing, perhaps you could enlighten us?
A Bush is a bearing designed to hang a shaft. Fact! Usually in vertical applications ie fans.It isn't a bearing.
Its a bush.
It’s a slip bearing and construction is from one piece as opposed to roller bearings.
It is however, a bearing!
If you don’t believe me I will cast a spell upon thee and thou wilst be doomed to an untimely mishap on an ascending ladder. Be warned.
I also have all the socks you lost in the washing machine! Thou art an argumentative scrote! Be told.! X
The only other comment I'd make is if there was damage attributed to the (professionally) UN-serviced gas appliance would your insurance pay out?
I had my Potterton profile for over 20 years and never had it serviced. Didn't know you had to! I did replace the PCB three times though plus the the plastic temperature knob and bottom cover broke through age/brittleness. When I had my system converted to sealed with unvented hot water, I had a service and flush then. It never ran right after that. Had the gas valve one other bit replaced and it started kettling so I had it changed before it broke down.There is absolutely nothing to service or adjust in my Potterton so i don't.
I grease the fanbearingbush every year though because Potterton thought putting the self lubricating bronze bush bearing directly above the combustion chamber was a good idea....
According to HMRC publication, only 37% of the registered business who register as an employer whose primary business is plumbing are vat registered.If they are charging £60 plus VAT, they are VAT registered. As an aside, I don't know any gas safe plumbers that are not VAT registered.
Not even the team?...I was at Leeds match recently and I could not find one person who was not a Leeds supporter....
Use them at your peril, what a nightmare.Bright Burn Solutions - Gas & Boiler Services
