- Joined
- 23 Jan 2022
- Messages
- 2
- Reaction score
- 0
- Country
Hello everyone,
My home has a BAXI DUO-TEC COMBI 24 HE.
The radiators won't heat up even though the boiler is showing a green light saying they are running. The hot water is still working though.
I've tried bleeding radiators and then pressurising the boiler after but I still have the same issue. The only way I've got the radiators to heat up is by opening the valve on the right, at the back ("heating return" according to manual so im assuming this needs to be open) but leaving this open causes the pressure to raise above safe levels. It went all the way up to 4.
If this is just a simple set up issue then that saves wasting an engineers time and money too.
I've included pictures of when the valve is open but I currently have it closed due to the pressure issue.
Are the valves in the correct position for normal operation?
