I'm telling you that the electrician put it in last week.
Strange that it looks old and has old screws.
I can see exactly what’s happened here, that socket does indeed look new- albeit a cheap brand.
The plug could not have been changed as when plugged into the new socket, still created a poor connection due to previous heat damage and thus caused it and the socket to overheat again. You can see above the live pin a brown mark from the plugs fuse which was hot.
A new good quality plug and socket would of prevented this.
Is this not heat damage?
In just the right place for this discoloured mark.
Both the socket and the plug now need replacing...So i was right it is heat damage. Does that suggest that the socket is functioning ok but the fan heater and it's plug are dodgy?
Someone said its 45 year old box, so may be BA thread, who carries new BA screws on there vanStrange that it looks old and has old screws.
Plug looks totally fine as you can see.
It might have been but it's buggered now.Does that suggest that the socket is functioning ok
The plug, yes. Fuse holder loose.but the fan heater and it's plug are dodgy?
To a blind man maybe ...that plug is knackeredPlug looks totally fine as you can see.
??????A new good quality plug and socket would of (sic) prevented this.
