Hello,
We are in the process of installing a digital shower. It will need a 3 amp switched fused spur to run from. The smart valve and the switched spur will both be in the loft.
We currently have an electric shower. The wiring for that runs into the loft, then into a ceiling switch, then down into the shower itself.
Would I be able to take the cable which goes into the ceiling switch and run it into the switched fused spur? Is this a job I can do myself or do I need an electrician?
David
David
