Tadpoles then after awhile minnowswhat is the barrel going to be filled with or used for ?
its a oak whisky barrel in my opinion cut in half so fill it with water until it leaks no more ??
at that point fill with i assume earth and plant
iff it dries out it may come loose so do not line with plastic in my opinion and without plastic expect perhaps 5-7 years off use but just a guess
Just so you know, taking tadpoles from the wild isn't legalTadpoles then after awhile minnows
you can try it for a week and line iff necessaryIf I dont line it , then fill with pond water, will it contaminate the tadpoles, fish etc?
Lilly padsTadpoles will need somewhere to crawl out as they start to change into little frogs, a steep sided container such as you have would not be suitable.
No, with this idea you're just going to kill off a generation of frogs in your area. Stagnant water goes green and stale with little oxygen, it'll also evaporate quite quickly as it warms up as such a small body of water. When you top up with tap water, you're also topping up with fluoride.
Nozzle
