My drawing was for the relay I suggested.Thanks for diagram, so A1 live A2 neutral… is B1 not used? Are you able to draw on this photo easy for me to understand? Thank you
This would be better:
Screwfix is wrong.Thanks, I looked at that Screwfix relay, it says the size of the suitable cable is a minimum of 6mm.
When you switch the override off, Sometimes you may find all the lights stay on if one of the PIR's is triggered. It's not a fault, just a quirk of the way it's wired.Just to say I purchased the screwfix option suggested by Sunray, wired as EFLImpudence diagram. Happy to confirm working exactly as described. Thank you all that contributed to the thread, really appreciate the support.
How so ? That implies that with the relay on, a supply from one of the PIRs can hold it on - but the switch is in the supply to the relay coil so with the switch off, there's no route for that circuit.When you switch the override off, Sometimes you may find all the lights stay on if one of the PIR's is triggered. It's not a fault, just a quirk of the way it's wired.
There is when the relay is energised.How so ? That implies that with the relay on, a supply from one of the PIRs can hold it on - but the switch is in the supply to the relay coil so with the switch off, there's no route for that circuit.
Are we talking about the same setup ?There is when the relay is energised.
Open the switch, there is then no connection to A1, therefore no current through the coil, relay opens - regardless fo state of the PIRs.I suggest go back to Screwfix relay (contactor), Bernards enclosure and circuit in posts #20, #22 & #25.
So, no we're not talking about the same setup then. I'd have done it as you drew it.This is what has been installedAre we talking about the same setup ?
I'd have preferred that but I don't know how the existing is cabled and wired, it may not be easy.So, no we're not talking about the same setup then. I'd have done it as you drew it.
