Have seen bungalows with a ring of junction boxes in the loft, and a spur going down to each socket myself. It was a 60s build. Terrible design. If only the 'spur' was 4mm2 or imperial equivalent.
Also seen many houses with concrete floors, the upstairs sockets wired as a ring under wooden floor, with a spur from each of these sockets supplying each ground floor socket. Again, no 4mm2 in sight.
I do know of one occasion where a relative electrician of mine did fit many ground floor sockets as spurs from above, and did use 4mm2 - although he said he chose to use 4mm2 because he was running them in filled cavities!
I have to say, I don't see many instances where rings have been added to with 4mm2, although have seen one only this week. Harmonised 4mm2, so not exactly ancient.
