Hi there,
I have two waterbutts - an 250L amphora urn style from Garantia (impossible to access the inside of this one) and a regular Ward 210L from B&Q. I want to connect them together at the bottom so I only need a tap the urn style, with the other sitting behind it, water levels rising and falling together.
On the urn there is a screw-in drainage plug socket I can use, on the regular one I can take out the tap and use that socket, they have the same dimensions so guessing it must be a standard size - apx. a 9cm circumference, there is eventually a question on this!!
I bought a connector kit from B&Q (see first picture), but this is designed for new holes, I cut off the flange (intended for inside) on them, screwed into both waterbutts, but only a couple of turns for the urn - which increases my concern that without washers/flanges they are going to leak with all the pressure they will have to bear.
I think I need to buy something better suited to the job, such as the brass ones in second picture, however there is a variety of size options, any advice on what size required for these connectors? Any other advice also would be much appreciated.
