Hi all,
My missus wants the living room separated from the stairs to help keep heat in (and save on ridiculous energy bills in the winter) so I want to build an internal partition wall with a door in it.
It's a concrete floor so I'm happy fixing the bottom part of the partition wall to the floor.
However, I need advice on the top part of the partition wall? Does that just fix into the ceiling plasterboard? Or do I need to lift the upstairs floor and put in another joist for it to fix to? The joists run in parallel to the top of the proposed partition wall.
Part of me thinks that fixing it to plasterboard and then using the verticals to support it (and then putting noggins between the verticals) will be strong enough but wasn't sure the 'correct' way of doing it? It will be a nightmare to lift the floor upstairs as it crosses two rooms.
Thanks for your advice
