Is this the case when you are squeezing two cables into the same terminal too?My opinion is that doubling the end of a single conductor can reduce the risk of the conductor moving into an area where the screw is not able to exert adequate pressure onto the conductor
On a ring circuit, where you have two 2.5mm cables, do you double over the cables into each terminal? Whilst I understand the principle, I wanted to understand its application in this situation please.Best practise is to aim to fill a terminal with the copper, to maximise contact area between wire and terminal.
Im sure I bend over a single wire, but dont if there are 2On a ring circuit, where you have two 2.5mm cables, do you double over the cables into each terminal? Whilst I understand the principle, I wanted to understand its application in this situation please.
Depends on the type of terminal and how well it is designed and manufacturedIs this the case when you are squeezing two cables into the same terminal too?
maybe because the designers have never installed any electrical wiring in the real world.Why do some electrical terminals and boxes seem to be deliberately designed to be awkward??
