- Joined
- 22 Sep 2015
- Messages
- 50
- Reaction score
- 0
- Country
We have electric gates, driven by FAAC control unit that uses remote key fobs to open the gates. The fobs are FAAC XT2 433 SLH LR. As the name suggests they operate on 433 MHz. However, the range is non-existent. Literally need to be next to the gate to open it. This does not seem correct to me, as ideally it would work good 10-20m away so you can open the gate as you drive up.
Had a brief call with FAAC and they said this is known issue/range of 433MHz which is what they are allowed sell/operate in UK. In the rest of Europe they use 868MHz and "this is much better". Is this correct or was I fobbed off? (excuse the pun!) Does 433 mean you can only achieve a few (<3 meters) or is something wrong with our setup? I will get the installers back next month but want you clever people to let me know what I should be expecting.
There is a lighting pole about 7 metres away from the control board, and of-course the board is affixed to a brick wall. Both might cause interference. Related, our garage door uses 868MHz and works fine, but that is not directly in the area of the electric gate. Is there is a difference between 433 and 868 (in terms of range/interference)?
Anything I can do? Perhaps get an external aerial but it will be unsightly no doubt.
