I've done some DIY electrical work on my house that I understood to be non-notifiable, I could potentially be wrong however:
- Added two new double sockets to two rooms by breaking the rings, adding some short lengths of new wire and joining under the floorboards with WAGO maintenance-free boxes
- Added two additional lights to an existing light switch/circuit
- Replaced a fair bit of old exposed & damaged T&E in the attached garage with new SWA, put in suitable glands, replaced the sockets and added some new ones. This was previously all running off an unfused spur from the downstairs ring so I've put in a 13A fused switch so that the garage doesn't overload the spur.
I haven't done any work in special areas like kitchens / bathrooms / outdoors, haven't touched the consumer unit (other than switching off the power), and the cable to the garage was already existing, so my understanding this is all non-notifiable work.
When I come to sell the house, do I need to declare any of this work, and will I be asked for an EIC? My understanding is I can't get an EIC on this anyway as an electrician can't certify someone else's work.
I'll definitely get an EICR - so will this be sufficient to sell the house without problems?
Or have I completely F-ed up by doing all this work myself and need to get it re-done by an electrician?
