Overboarding shed.
30 Jun 2008
Suffolk
Need to overboard a shed because the joints have opened up and you can see through the gaps.
Which is better, shiplap or feather edge? Could you use fence panels and, if so, is better to have the boards vertical or horizontal? Current boards are horizontal.
Distance between uprights is 1500mm between centres and overall height is approx 1800mm.
Surely is. It is a modular shed built up from panels so you can make it bigger or smaller simply by buying the appropriate number of panels and roof sheets.
Between the horizontal boards. In this dry/hot weather they have shrunk and opened up.
I think there are intermediate vertical supports between which, I suppose, will be at around 750mm centres.
