- Joined
- 27 Jan 2008
- Messages
- 28,887
- Reaction score
- 3,534
- Location
- Country
I have like I am sure many others, used some smart devices, in the main they are controlled local, "hey google turn on landing lights" for example when I approach the stairs with two cups of coffee one in each hand, so can turn on lights without risking spilling coffee down the wall.
However although normally used local, I can also turn on the AC for example before returning home, and get the home cool ready. Be it a battery charger, AC, fan, outside light, we have loads of items connected to the mobile phone which can be remotely switched on. Well also off of course, but on is the bit worried about.
Has a dog, cat, or other knocked over a device, has there been a flood, is some one trying to work out why it is not working, when it is remotely turned on, has the radio said hey google, or alexa turn on something, or grandchildren set a timer to give grandma a surprise when TV turns on.
Today anything with a 13 amp plug and be remotely controlled, I have not set the kettle or toaster to turn on with voice commands, but easy enough to set up.
So if anything on a 13 amp plug can be switched on remotely, what about safety should some thing go wrong. I remember a batch of angle grinders being returned to supplier as the on/off switch could be latched on, this was not considered safe, some one could try to use the grinder, find it did not work, and investigate and plug in an extension lead, and grinder start to destroy things until the error is noticed.
This was not considered a problem in the home, only when loads of people working in one place, I try to consider scenarios and do a risk assessment, but does everyone.
