- Joined
- 1 May 2018
- Messages
- 2,292
- Reaction score
- 778
- Country
Unfortunately yes, you haven't used the brackets in the way they are designed. Look at the illustrations here https://tinyurl.com/46ysskad which show the brackets fixed to the timbers. The bracket has to be fixed so as the pins slot into the slots the slope of the slot draws the joint together. You have to fix them so that when the pins are bottomed out the timbers are drawn very tightly together.
I don't like brackets, and IMHO you would be better off with cross-dowel bolts which you can tighten up as tight as you want. Only thing is, as previous, if you don't want to see the bolt heads you have to recess them and put plugs in. Personally, I don't mind the heads showing.
