Needs to be fail safe,Wireless Panic Button
And reed switch’s in panic buttons can stick …..Needs to be fail safe,
Does the wireless panic button send regular "No panic link test" messages at regular intervals ?
Will the panel react if these test messages fail to arrive at the panel ?
Much easier to be fail safe when it is a wired panic alarm.
True, two in series reduces the risk of the panic button not going open circuitAnd reed switch’s in panic buttons can stick …..
Do they work with the UR2-WE now?Pyronix UR 2 and HUD-WE ,but as mentioned this would not be cheap.
You can program the keypad with a panic function by pressing 1&3 together. You will need the engineer code for this.
The panel will ( should ) show "No Panic Activated" which proves the loop is intact,How do you test that after installation?
