Rising Damp - Fact or Fiction?
  • Thread starter Thread starter kettlemanjim
  • Start date Start date
Surely a brick wall right next to a water source should have damp rising up it?
Maybe the water is evaporating on the external surface due to air flow, sunshine etc?
Are you suggesting that none of that water can penetrate those walls?
I'm sure cowboys do this, but not seen anybody here suggest that.
I've experienced it - my mum got a damp 'specialist' to look at their house. They wanted to inject chemical above a perfectly serviceable slate DPC. Madness.
It's no good having people with chemicals to sell to survey your house. And they need to have an understanding of material science and old buildings.
The issues the had was:
- gypsum and cement plasters
- high ground levels on some walls
- concrete hardstanding bouncing rain onto the walls
- insufficient heating
- new double glazed windows with no trickle vents
- no extractor fans
All classic reasons for damp problems yet the chemical man thought they should inject bricks. It's utterly crazy.
Did DPC's exist in the 16th century?
If "yes" they must have been needed. If "no", then they must not have been needed. :unsure: :confused:
From the following
There is no doubt that rising damp by capillary action, caused by the progressive rise in the water level, is the main reason why the entire fabric of the city (around 15,000 buildings) is degrading.
- no extractor fans
How do you service a slate DPC? Do you pull out a section at a time and replace it, and if yes how do you bed the mortar in fully?
You don't need to go in. Look at the brick walls!
No stain, no lichen, no salt stain, no tide mark. No damp by the look of it. Why not? Surely a brick wall right next to a water source should have damp rising up it?
Maybe all those buildings in the photo have lovely injection DPC's?
But slate can crack.
Why would it crack? I've told you - there were clear and obvious reasons for the damp which the 'specialist' completely ignored. I've remedied all of them and have no damp problems. Dpc never touched.
A slate dpc is formed from two layers of slate bedded in mortar.
Well, at least they didn't suggest filling in all air vents as a method to stop moisture getting under the floor!
Yes, that's what happened to my house - previous owner must have had some really bad advice, and probably why they sold it in the end.
I am not doubting that they were trying to hard sell a product that wasn't required but houses do move. I work in London, as the clay dries out it contracts and the slate can fracture.
OK. In that case I'd be more concerned about rain water coming through the crack in the wall than rising damp. Presumably a crack would destroy any alleged capillary action.
When I've more free time I'll do my own experiment with old bricks on whether water can actually seep up beyond a discontinuity such as a mortar joint.
Fair call.
All I can say is that I have worked in houses where the only remedial work was drill and inject. It worked.
Please do report back
Injection does work where the moisture is not under pressure, or where the wall components are otherwise suitable for the voids and capillaries to be treated.
The discussion is about rising damp, not sideways damp.
I think we can all agree that water can travel sideways.
