At some point my old Stelrad Ideal Elan is likely to need replacing.
We have been here 21 years and it was here when we moved in. New gas valve about 15 years ago.
Is it worth replacing for better efficiency? It works fine.
In the last year or 2, I have removed and flushed all the rads. Ran some X400 for a few weeks and fitted a magnetic filter.
Temp is either low or high. No adjustment. Run it on low most of the time. Only high when very cold out.
Hot water via a Fortic cylinder in the loft. Hot water flow is OK but not great.
It is located in a cupboard in our en-suite
The guy who replaced the valve had a bit of a moan that he had to lie down
Could a replacement go into the same place? Pump and 3 way valve in the main bathroom.
