I have over a couple of years (with Building Regs application ) been building a detached Carport & Garage.
The wiring has been in and working as an RCD protected TT circuit from the house with the ccts local earth rod at the garage end.
Having now finished all the work, had an electrician in, to inspect & certify ..... I asked for what the Building Control dept. said they wanted - 'Electrical installation certificate under part P'
He inspected and tested and advised all was fine, (no surprise as had already tested it myself) he completed a significant document and I sent it into Building Control.
It was a 'Domestic Electrical Condition Report' under requirements for Electrical Installations - BS7671 IET Wiring Regulations.
Today Building Control rejected it, as it was stated as Inspection of Wiring carried out by another.
Went back to the Electrician he said this is perfectly normal process, as long as he thoroughly inspects the installation, he can certify it ..... as can happen if an original guy is no longer around (ceased trading, dead etc|).
Building Control totally refuse to accept this - they insist that the original installation electrician must sign it off, not a 3rd party.
The only other option is I pay Building Control £322 and they then inspect & certify ...... I asked what qualification their guy has that my electrician doesn't .... they said it's irrelevant, it's their scheme that is key not the qualifications of who is doing the work.
They also (and this annoyed) said they don't do it themselves, they just put work to an electrical contractor.
This seems like a money-making scheme for the local authority.
I get the same electrician to carry out Landlord inspections and issue Electrical safety certificates, I asked how are those acceptable to you, as that is on properties he did not install ? ..... told that is irrelevant this is not Landlord Scheme.
Anybody found a way around this - or do I just have to pay £322 (having already paid my electrician once)
