purchased a new build 4 years ago and after the 1st winter we knew had a problem. Had thermal imaging survey done which showed no continuous ribbon of adhesive and either no or incorrectly fitted cavity closers. Had expert witness structural survey done which showed no dpc around doors and frames, plus issues in loft and many other defects. Went legal and now 2 years later we have reached a settlement with the developer. The sum awarded to me would cover 75% of the costs involved to do the following:
Remove all dry lining and apply ribbon of adhesive along with new skirting boards. Removed windows, doors and frames, install dpm and cavity closers. Replace carpets and redecorate.
Would I achieve similar results by removing skirting boards and using foam to seal along the bottom of boards and wall? Could I inject foam along the tops of walls on both ground and first floor?
It has been suggested to me to remove dry lining and then wet plaster instead as this would reduce heat loss even more, but unfortunately I dont think the sums awarded to me would cover enough of it.
For the windows and doors I think the only way would be to remove them all and do it properly unless anyone has any ideas?
I ask because Im worried that I will use all of the money awarded to me, plus a lot of my own money doing it the right way (full removal of dry lining etc) only to find it hasnt made much difference. Im also worried that injecting foam wont make much difference either!
Any advice would be greatly appreciated.
