You'll have to devise a method which is "secure/tight enough.... two; the connection is not secure/ tight enough
The connection presumably does not need to 'survive' for very long for you to see if you're able to get s picture?
Well, you learn something new everyday!That wont work! for 2 reasons
One; you have not grounded it
Only 10p more for the gold plating!In which case you will need a phono lead and a BNC to phono adapter:
https://cpc.farnell.com/pro-signal/rw1-033/adapter-bnc-male-to-rca-female/dp/CN15992
Is it real gold though?
Very probably, but probably thinner than you would think was possibleIs it real gold though?
Further more I read that a one oz of gold can be pressed out into a 1 meter squared sheet, with a thickness of 23 atomsVery probably, but probably thinner than you would think was possible
I would think so, if not more!Much bigger than a metre. Could it be a hectare?
That, coupled with its resistance to corrosion (such that the 'better connections' are maintained) is precisely why it's used in such situations (whether always 'necessarily' or not is perhaps a different matter1).Further more gold is a very good conductor or electricity which in this case will mean a better connection and hence a better signal
I cannot find fault with your arithmetic.Please correct me if my logic is flawed! ... ...and here I am only talking about the plating thickness of electronic components!
Typical coating thickness of gold in electronic connectors is 0.8 microns, over 1.3 microns of nickel. ... Assuming 24K gold.
...1cm³ of gold would cover an area of 12500cm² at 0.8 micron.
...1cm³ of gold has a mass of 19.32g
...1g of gold has an area of 647cm²
...1 ounce of gold would have an area of 18'342cm² or 1.83m² (...or 2.01m² if the ounce was Troy!)
...currently gold costs @£47.80/g ... 1cm² of gold plating would cost 7p in gold alone!
That gold plated connector is a bargain!![]()
Mr Google tells me that the diameter of a gold atom is about 0.000144 microns. If that is the case, if they could be jammed together 'across diameters', 23 would seem to amount to some 0.003312 microns, some 2,415 times smaller than the 8 microns of your plating. Hence, in relation to AstonHill's (23 atom) rather than your (8 micron typic electronic plating) situation, I g of gold ought to cover about 1,562,505 cm² (aka about 156 m² or 0.0156 hectares) - which is much greater than AstonHill's suggestion of 1 m², but a lot less than @JohnD 's suggestion that perhaps 1 hectare might have been intended.Further more I read that a one oz of gold can be pressed out into a 1 meter squared sheet, with a thickness of 23 atoms
