That's true, but I don't think it's consequences are adequate to explain the apparent 'anomaly' (aka a lack of understanding on my part!) I mentioned, at least in cases like my house, and many others like it.My first thought would be that the resistance may not be uniformly spread along the supply to your house. I'd imagine that the main supply cable feeding multiple houses has a much bigger cross section and lower resistance than the cable running from it to each individual house.
The run of (smaller) cable from my house to the (larger) distribution cable (which happens to be overhead, so I can see it) is quite short, very much shorter than the run of that distribution cable from where mine joins it to the transformer. I would therefore imagine that the majority of the L-N loop impedance I see from my house is attributable to the distribution cable - along which all current from installations downstream of mine (on the same phase) has to run.
See above. Whilst I understand what you are saying, and agree that it is a 'factor', I don't think it's an adequate explanation for installations that have a short length of (admitted higher resistivity) connecting them to the distribution cable.When running your 10.5KW shower it could well be that most of the voltage drop occurs on the section of cable feeding your house from the main supply, and only a small part of the voltage drop is occurring on the larger main supply cable.
to the best of my knowledge, yes (but, of course, I know that there's 'something wrong with my knowledge'!).EDIT: Another thought is how the main supply cables from the transformer are run. Are they simple radials from the transformer with branches out to houses along its path ...
As above, I think (same caveat as above!) not ('in normal service') . In any event, again in relation to my particular supply, I can see the (overhead) 'main distribution cable' all the way to the end of the run, and it clearly is not a ring., or maybe some kind of ring formation from the transformer which would also reduce resistance and the voltage drop on the main supply cable.
Indeed, but my understanding (caveat again!) was that they were not left as rings when in normal service.I know that there are junctions on supply cables that allow DNOs to rearrange supplies to bypass sections if needed, I believe there is one such junction in a manhole not far from my house.
Does anyone know the CSA of a typical LV distribution cable. If we knew that, we could roughly estimate the contributions (to resistance/impedance) of the parts of the total cable run.
However, as per all the 'caveats' above, I know that there is something wrong with my reasoning, so some (maybe all!) of what I've written above may be wrong, maybe even nonsense
