New keys and locks needed
20 Oct 2010
Lanarkshire
Hi my daughter has just moved and looking to replace the 2 doors cylinders, can I ask how do I measure replacements
I believe that you just measure the length of the cylinder. To remove them, take out the single screw that holds it in place (from the door edge). Put the key in an twist it slightly, that will let the locking lug move to the downward position and enable you to remove the cylinder. You don't need to remove anything else.
The lock type is a euro-cylinder.
eg https://www.screwfix.com/p/union-6-pin-euro-cylinder-lock-45-55-100mm-satin-nickel/5371g
The above is just intended as a guide and not a product recommendation.
If it is a front door, does the inside have a thumb turn?
Again, just a link, measure yours first.
Thanks will go down tomorrow and measure it, don’t think it has the thumb wheel on the front door, although the back is key inside. Can I ask if I have to renew them any point in changing the inside from key to thumb wheel?
The thumbturn means it can be opened from the inside without a key
Useful in an emergency such as a fire
But if there is an opening that a hand or simple tool can access, such as a letterbox or breakable glass, so can a burglar outside.
Thanks will talk it over with her
Sorry can I ask is this a 50-50 or a 45-45 ?
You measure to the centre of the screw so it looks like a 50-50 as listed at Screwfix as "50-50 (100mm)"
But if the end of the old cylinder poked out of the door, try to get a shorter one that will be flush with the escutcheon on the outside
(You sometimes see the 10mm central cam measured separately, then it would be a 45 -10-45)
Thanks it was the central cam that was throwing me, Screwfix looks like it’s 50-50 but Toolstation looks like 45-10-45
Yes some retailers even manufacturers list them like that but its the same thing
If you are buying new cylinders, then best to get them suited or keyed alike, so that the same key operates each cylinder.
And remember to get the anti-drill and anti-snap type. Look for TS007 standard and 3 star - although the star rating requires other ironmongery to comply too to make it a 3-star system.
Be careful about installing 'Thumb Turn' type - your house insurance may be affected (or even invalidated). The company I use have a specific question about such locks and load the premium if Thumb Turn locks are fitted.
Good point. I have four locks at the back of my house to work off the same key. I dislike carrying great bunches, or not having the right one to hand.
Can I ask where do I look for the matching keys
Ultion cylinders come to mind. Either direct, or a local lock smith that is an agent for them. Then once a key is registered you only need that number to have keys or cylinders made in the future, and no one can cut a key without your permission.
My local locksmith will happily cut such keys with proof of ID and utility bills and completion of a form. I'm now registered with them to make it easier each time.
Makes a farce of the whole system
