Hi Folks
My daughter has replaced her kitchen sink.
Her old sink was a 1 1/2 bowl single drainer in resin and has been replaced with a stainless steel 1 1/2 bowl single drainer.
The washingmachine drains into the same waste as one of the bowls via a spigot (is that correct?)
A "plumber" took out the old sink but couldn't plumb the new sink in immediately.
I have fitted the sink and connected up the hot& cold taps (both work) and the cold feed for the washing machine.
BUT, I have tried to refit the old waste onto the new sink but it has got me completely stumped.
There seem to be three different pipe sizes 40mm, 38mm and 32mm.
This diagram explains what I've got and there are also two pictures.
I have pipes to connect to the sinks A and B.
I have the spigot (?) to connect the washing machine waste.
I need a trap to fit at C and D and some sort of joint (I've called it a 'T' joint) to join both sinks and washing machine to the grey push-fit waste pipe at W.
Can someone please explain what fittings I need to achieve this - preferably using either Toolstation (preferred) or Screwfix SKU/Part Numbers so that I can get this fixed up ASAP.
She has two small children (one 4 and one 6) and curretly can't use the sink or washing machine (obviously) nor the upstairs bath or hand basin (as water leaks out of the grey waste pipe at W)!
THIS IS URGENT!
She has been without a kitchen sink for the last week and today was the first day that I could go round to try to sort this out for her.
She has tried local plumbers but nobody could come out before 11 Nov (leaving her virtually two weeks without use of the kitchen sink and/or upstairs bath & basin.
Here are the pics of what is already under the sinks:
and
'E' in the picture above leads off to the washing machine waste pipe.
Please bear in mind that whilst competent at DIY, I don't pretend to be a plumber so please explain in simple terms what I need and where, and, if possible, using Toolstation or Screwfix SKU/Part Nos. so that I can get this sorted for her.
Any help gratefully received.
Many thanks,
Dave
THIS IS URGENT!
and
Many thanks,
Dave
