Forum playing up? + one other
  • Thread starter Thread starter Deleted member 267285
  • Start date Start date
D
Not sure if the forum is playing up? I read my alerts, and when I go to refresh or switch back to the forum tab, there’s alerts unread which I've already read? Attached an example
Also, do we know why the bulletin points have disappeared?
Half the time I get no alerts when there should be one, the new software also has trouble with names so you get “1 person likes this” or “deleted member”
Blup
Blup
Yep, had this early on and noted it in the forum issues iirc when it was 1st transferred over.
Has the forum got an issue with images currently? If I click on them I get this (if you can view it)
Yes, is that the problem?
Seems to be. I was using my own iPad which is about version 13, whereas my work iPad is version 15 and this appears to display everything as normal.
Do you know why as is it only happening on this forum & how it is rectified, it's been ok until recently
No idea why it’s this forum only, maybe the forum has updated? I would think to rectify it either try a different browser, eg Chrome, or update iOS.
They have stopped supporting the old model ipads, it will get worse, time for a newer model?
Blup
Apple, I imagine that when they withdraw support there comes a point where the old software simply wont work for what is important.
Blup
