- Joined
- 26 Nov 2022
- Messages
- 5
- Reaction score
- 2
- Country
Hi all,
I currently have installed a Danfoss FP715Si (TP9000) 2-channel CH/HW programmer, but the factory-set clock is entirely wrong and it is just getting old. So it is time to replace it with something more modern. Ideally, I would like to be able to replace it with something that can reuse the existing wiring and backplate to save having to install a new backplate and rewire it. So, my first question is are there any new models that would fit the existing back plate and wiring configuration? I believe the wiring configuration is:
This is a picture of my actual backplate and existing wiring configuration.
Earth, neutral and live is fairly self-explanatory. Am I correct in thinking that the following applies?
3. HW off
4. CH off
5. HW on
6. CH on
If not what would be correct?
If there are no 2-channel CH/HW programmers/controllers that would fit the existing backplate, are there any new controllers where the backplate can be replaced and the existing wiring could simply be rewired (copied) over to on a like-for-like basis?
Some models that are well-reviewed on Amazon and have caught my eye are:
- Horstmann H27XL Programmer
- HONEYWELL ST9400C 7 DAY HEATING PROGRAMMER
- Drayton 25473 LP112 (Mk4) 2 Channel Programmer
- Drayton 123070 LP522 (Mk4) 2 Channel Programmer
Some questions for your expertise please:
Are any of these suitable replacements?
If more than one is a suitable replacement, which would you recommend?
Could any of them use the existing backplate and wiring configuration?
Could any of them have the backplate replaced and use the existing wiring configuration?
I apologise that this has turned into a bit of an essay, but any expert help you could pass on to me would be greatly appreciated.
Many thanks in advance,
Mark
3. HW off
4. CH off
5. HW on
6. CH on
Mark
