- Joined
- 22 Jan 2007
- Messages
- 8,525
- Reaction score
- 4,533
- Country
Hi all.
Is it possible for a cheap or faulty solar PV Inverter to cause errors on other equipment?
By this I'm specifically thinking Heat-Pumps which contain an inverter of their own to convert the mains voltage to the 3Phase signal needed by heat-pump compressors.
Been told that when an error code on the heat-pump relating to inverter/frequency issues appears that it can be caused by dodgey solar PV equipment. And was wandering if this would be testable on standard non electricians test equipment.
I've got a multimeter that can read out frequency, and I cant remember ever seeing a mains supply show anything other than 50Hz. But if there was an issue with PV inverters could this change that measurement?
