TL : DR
the TV advert with a Freddy Boswell look alike clapping his hands is a figment of some ones imagination
On Amazon I've seen 'Fan Heater 1200W/600W' for about £50 - these ones are ceramic.
I agree in the main, does not matter what resistive method is used. Energy in = energy out. However thisYou get all of the watts you pay for, ceramic or not. Ceramic is mostly kidology, no better, no worse than a straight-forward fan heater.
simple cheap heater is not simple resistive, it also sends out infrared energy, this does not heat the air but passes straight through the air, and heats what it is aimed at, it has also many disadvantages, the heat can pass through most windows even if double glazed, and it is hard to automate control. As a result often they have multi bars, so user can select how many bars, and rarely have a built in thermostat.If it's not "simple resistive", what do you think it is - do you think its load includes an inductive or capacitive component?I agree in the main, does not matter what resistive method is used. Energy in = energy out. However this <pic> simple cheap heater is not simple resistive, it also sends out infrared energy,
If you're talking about the IR radiation, that passes very poorly through ordinary glass. That's why greenhouses work - the glass lets UV light in, which heats things and hence causes them to radiate IR, but the glass won't let the IR out. You're into photography - if you've ever tried to take an IR photo through ordinary glass, you will know that it is essentially opaque to IR!.... this does not heat the air but passes straight through the air, and heats what it is aimed at, it has also many disadvantages, the heat can pass through most windows even if double glazed ...
agree in the main, does not matter what resistive method is used. Energy in = energy out. However thissimple cheap heater is not simple resistive, it also sends out infrared energy, this does not heat the air but passes straight through the air, and heats what it is aimed at, it has also many disadvantages, the heat can pass through most windows even if double glazed, and it is hard to automate control. As a result often they have multi bars, so user can select how many bars, and rarely have a built in thermostat.
Yep, I also remember them well (might even still have an example in cellar or attic). As you say, almost entirely IR heating, so I also remember us huddled round (very close) in front of it, with scolding hot faces and very cold backsI agree, apart from, as pointed out by John above. In fact our first ever electric heater, back in the 50's, was of that IR type as were almost all back then, so nothing new. From what I remember it had two bars, wire wound on some sort of ceramic former, which a massive switch on the rear and portable. It had very exposed live hot parts, just a narrow guard directly in front of the element, and large reflector behind it.
If you're suggesting that such an element will have significant inductive or capacitive reactance at 50Hz, then I disagree.For practical purposes yes.
I know all that, without the need to do any Googling. However, didn't you realise that my question to eric was essentially sarcastically rhetorical? It surely is the case that the load presented by such an element will be almost entirely resistive, with the inductive and capacitive components being negligible at 50Hz - and that would remain the case even if it were not "non-inductively wound".Firstly it will be "non-inductively wound" (I suggest you Google it) and secondly, any capacitive or inductive component will change the power factor of the heater. However, as you don't pay for the imaginary power even though it has to be generated (again Google it) any capacitance or inductance in the heater is irrelevant to the amount you pay.
As with most things, it's not quite that simple!if you've ever tried to take an IR photo through ordinary glass, you will know that it is essentially opaque to IR!
Fair enough (and, as you say, few things are 'simple'!!) - I certainly don't claim to be an authority on such mattersAs with most things, it's not quite that simple!
Hmmm - well if that's true, it's certainly contrary to everything I've been taught and believed. Also, that presumably could not explain atmospheric/global "greenhouse effect", since I can't see how the presence of greenhouse gases in the upper atmosphere could/would 'reduce convection' (I must see what the wiki has to say about that!)....and as for the "Greenhouse effect" in an actual greenhouse (see "Real greenhouses" section)...
According to Wiki, the effect is due mostly to a reduction in convection. However, there are plenty of other sources that repudiate Woods findings!![]()
Greenhouse effect - Wikipedia
en.m.wikipedia.org
You've surely sat the other side of a window on a sunny day before, so must intuitively know this isn't true.If you're talking about the IR radiation, that passes very poorly through ordinary glass
You mean on the 'other side' from the sun? If so, then it's the UV radiation from the sun which passes easily through the glass and which warms you up (and hence causes you to radiate IR).You've surely sat the other side of a window on a sunny day before, so must intuitively know this isn't true.
