Help -Installing a toilet/basin combo with only a cold feed?
5 Jan 2009
Hi all
Looking to replace my old toilet with a toilet/basin combo.
I’ve fitted a few toilets and basins separately but never a combo?
I’m looking at this combo pack as it comes with a monobloc tap but I’m baffled as to how the tap gets its feed as the tail/s must go into the cistern?
I think I can see two inputs in the bottom of the cistern? Are these the hot and cold?
If they are what do i need to just make it a cold water fed system?
I’ve watched a video but it does not show how the tap tail or tails are connected?
Anyone help please?
Perhaps it’s installed like this?
Wow.
That’s an odd design.
I have messaged the seller for instructions.
IF it is like that then I would need to split the CW feed.
One for cistern fill and one to the CW of tap flexi.
I presume the other HW flexi would also need to be fitted to prevent backflip from the CW one?
I would just have it dangling and fit an 1/2” male plug??
Seems a silly way to do it though??
Yes, it would need to be blanked, but you might as well try to plumb it in.
It’s a massive job to run a HW supply as the existing toilet is in an outhouse and HW is not required at all.
Just seems a silly design tbh/way of doing it.
Cheers.
What about adding a water heater?
The other half just does not want HW.
So I’m happy. Lol.
I found a video from another one which looks the same but from Victoria Plumb.
It seems the CW inlet/fill has 15mm T/spur off it to connect the CW flexi too.
The HW will then also need to be fully fitted but just capped off on the outside/bottom of the cistern.
So it will need an 1/2” female cap with a rubber washer if possible.
Anyone know the correct terminology or correct item.
It’s basically the same flat faced inout as the CW inlet on the bottom.
Thanks guys.
