If your "work" area near the sink is seen by the pir, you could set the pir for 1 minute and as long as you are seen by the pir the light will stay on
I thought about a pir, but often I wash boots and tools in the butler sink there, so that's why I needed a switch.
Having the pir set at 10 minutes would be a waste of energy when I (or a cat) just pass by and I don't need the light.
Looks like the only solution is to have a separate switch below the light.
Is it more than the nothing when switched off?What do you think is the cost of running a 5W LED for ten minutes?
Not noticeably.Is it more than the nothing when switched off?
Does it not work with movement?If your "work" area near the sink is seen by the pir, you could set the pir for 1 minute and as long as you are seen by the pir the light will stay on
Yes, but if I am at the sink, only my hands would be moving inside the sink.As the PIR would sense your body moving it would keep the light powered, I have a PIR that scans my drive such that as you approach it switches four lights and just waving a hand in front of the sensor will bring the lights on.
