Hi there Iv got a question what I can't find a answer to and wondering if you can help ? Please be nice or don't bother
Iv had our new garage connect up to the main cu but now we need to add a 32amp commando socket outlet (for the new RV) we already the a 16amp for when our friends come down in there caravan ect
this is our layout from main cu to the garage cu
32amp mcb - non RCD side 6mm cable to small cu place next to main cu then the 6mm cable going in a rcd 30ma then feed the 4mm 3core swa what goes to the gargle ,then what goes into a metal box then goes into the garage cu, in the cu there is a rcd 30ma what supply's 16amp MCB - sockets , 16amp mcb - for the commando socket, 6amp mcb for the lights.
The 16amp mcb for the commando socket only draw 10amp as the caravan got it own 10mcb - this is only used when they come down
On the sockets there only a freezer what stays on nothing else
My question are:
can we add the new 32amp commando socket in the incoming power what goes into the garage rcd (we will use 4mm to connect it to commando socket)?
Will this be classed as a spur?
If it is classed as a spur I can connect it up? If not I'll call the electrian, that not a problem just don't want to waste money if we can do the work ourselves
It will be protected by the 32amp mcb in the house and by the rcd in the house. There will be no more than 20amp Max And it won't be used all the time only when it comes out of storage a few day before we use it
I
My question are:
I
