I haven't read all of the thread and I hope this has already been pointed out.I want to monitor how much energy our electric shower is using. The shower is currently on a Hager MTN132 B32 MCB.
I assume that this Hager MTN132 B32 MCB goes on to a busbar and has a single live wire connection at the top.
On Amazon and eBay, I have seen MCB's that have WIFI functionality which include metering and other programmable functions (see photo).
However these MCB's seem to have 2 (N&L) connections both at the top and bottom, like a double pole switch. So I wonder if they can be used to replace my Hager MTN132 B32.
Does anyone know if I can just swap these MCB's?
Can I just connect the live wire into the 'L' terminal at the top. Then connect the 'L' terminal at the bottom into the busbar?
Can I leave the 'N' terminals empty? Or does the new MCB need to be attached to the DIN rail without any busbar and have the shower circuit wired through both N & L terminals, like a double pole switch?
Thank you in advance.
These are switches (actually WiFi controlled relay), not MCB's
