Besides the depth, is there any other difference between the size of a 47mm and 35mm 2 gang dry lining box?
I'm not sure that "dry lining boxes" actually have "knockouts", as such, do they?
I have to admit that I missed the dry lining bit. I never have nor will use one of those so I don't really know. The pictures seem to show a single knockout in the back but that's not going to be constrained by the depth.
In relation to a 47 mm metal box, I think what you say may well be right.
Yes, they do. Circular ones in the rear and rectangular ones top and bottom.
I must confessed that I hadn't noticed, or had forgotten the round ones at the back (I certainly don't recall ever using them, and, given the situations they are used in, doubt whether I would ever want to, or necessarily 'be able to'!).
I'm aware of the rectangular ones but assumed (given the way you described it, with just a 'diameter') that you were talking only about round ones.
Can't remember mentioning diameter?
You didn't, but i doubt that you have a way of adequately describing a rectangle with only one dimension, and we all know what shape 20mm and 25mm knockouts are (and what measurement is used to describe them - clue .... it's not the circumference :) ).
