Hi all,
I'm in the process of buying a new house which was rewired in 1987. It had a new consumer unit installed 2 years ago however and I've been told that when this was installed, the cabling was checked and all was fine with it.
The sockets are located just above the skirting boards and so a little low.
I'm considering leaving the electrics as they are but raising the height of the sockets by removing the old sockets, extending the cables using wago style connectors and then installing new sockets approximately 3' from the ground (to help plugging devices in without causing too many problems to my back).
My question is that once the cables have been extended using the wago connectors, can these be plastered over - I'm not sure if moisture in the plaster can work its way into the connectors?
Many thanks in advance.
