- Joined
- 15 Mar 2020
- Messages
- 102
- Reaction score
- 3
- Country
Hi, wanting to get some advice on what to do here (you'll be able to tell I'm not the most experienced!).
Need to replace a fascia board and possibly put in new guttering too, find pictures attached.
The original work is rotting away, the worst section being to the left of the first picture, but there are other areas where I can already see issues as well.
The existing work appears to be 2 separate boards, not cut to same width, directly nailed in to the brickwork or whatever else is behind the boards. The gutter clips also appear to have been nailed in. The boards appear to be pushed up all the way to the top of the roof tiles.
What I believe I should do:
- Pull the guttering out.
- Attempt to pull the boards out without causing too much damage. Got my hammer and wrecking bar ready for this.
- Clean up a bit and install new board(s), nail in? Screw in?
- Fill any gaps with silicone.
I'm mostly concerned with what is actually behind the boards here, just brick I hope? Also, what material should I use for this job? Wood? If so, what to treat it with? PVCu like material? If anyone could link me to the right material here, that would be great!
Any other considerations I should be taking here?
