- Joined
- 8 Jan 2017
- Messages
- 15
- Reaction score
- 0
- Country
Morning All,
I am a qualified Electrician and am looking at installing my own AC unit. I have found one online that is a Pre Gassed - Easy fit - Split unit.
I am wondering if anyone has fitted these before, I spoke with the lad who was going to fit it as I originally paid for fitting, this was through Aircon Direct. He mention nowadays they are just plug and play so I have decided to give it a go.
I can attach everything to the wall and attach all pipes but a few questions.
1) The internal unit has a screw on the thin pipe, when I unscrew this it released gas at a HIGH pressure. I read online this is nitrogen to keep the unit free from condensation and water when storing. An that I have to remove this obvs to install the 5m pipes. Is this correct? Or have I broken the unit removing this.
2) My pipework is 5m long, I have screwed this onto the internal unit and drilled through the wall and taken this outside. The pipework being 5m is very long, I only req about 2-3m. Can I just simply cut this down? OR is the unit Pre Gassed with 5m of gas (If that makes sense) so if I cut it down will I need to lose some gas? If so how?
as above, if I cant cut it down, ill just have to coil it up behind the external unit.
3) If I can cut the pipe down, how do I go about doing this. I can buy a pipe cutter but is the end flared? So that the nut spins but doesn't fall of etc? Or am I best to cut the pipe down leaving the end on then connect the 2 pipes back together?
4) I've read online about pressure testing before releasing the gas from the external unit into the internal unit. I've also read a lot of American sites saying no need. If I have tightened all the internal connections and external connections nice and tight do you think this is needed? If it leaks gas, is this gas harmful? If not, does it have a smell so I can smell its leaking?
Thanks alot for your time and help!
Appreciate it
electriQ Black Multi-Split 3x 9000 BTU Heating & Cooling Wall Air Conditioner Sy 5056549327820 | eBay
Find many great new & used options and get the best deals for electriQ Black Multi-Split 3x 9000 BTU Heating & Cooling Wall Air Conditioner Sy at the best online prices at eBay! Free delivery for many products.
www.ebay.co.uk
Appreciate it
