Hi all,
I need some advice. Our stopcock is peeing water in the basement. It's right next to the electricity meter and fuse board.
We can't find an external street meter or stopcock and the water board hasn't a clue where the feed is. So I've excavated the back yard and exposed the pipework. It seems the mains feed is in yellow 25mm MDPE pipe. The stopcock in the basement is attached to 20mm blue MDPE. I'm assuming they ran the 20mm blue inside the 25mm yellow.
The house was built in 1992. Why would they use yellow pipe? Is this common practice?
I need to use a squeeze off tool to cut the supply so I can fit an external stopcock. Will clamping off twin pipe work or do I need to cut out a section of yellow pipe first?
