Make that section a recliner.There's a bench being built into the front of it, so would look a little odd![]()
It's one of those floating ones. Bit like thisIs the bench fixed down?
If you have never had the top off, how do you know that it is only for your kitchen?
Are you the first on the run or last?
Even if the only feed from your land is clean/ brown water, a blockage further up can be rodded to cause your garden to flood with sewage
as said, these things don't block at 8.00 am on a sunny summer's afternoon. It will be peeing it down, midnight, and your shoes will leak.
at the very simplest, lift the dam thing before you do any work, it could be on the point of collapse and you are about to try to wall it in.
the least that you can do is ensure that it is in ok condition
Only if you don't do it properly and use some cheap crap. Haven't decided on a finish yet anyway. Might be white, might be coloured, might be tiledOh no have you fallen into the white render trap where it either discolours or falls off in a year?
They would have to be of supreme quality, so as not to become seized through lack of use. They rarely behave the way you'd expect.Build a section of planter on heavy castors
A couple of scaff poles under the planter, with another couple in the shed works.They would have to be of supreme quality, so as not to become seized through lack of use. They rarely behave the way you'd expect.
Built a bar on castors , wheeled it round the garden for years without problem .Doesn’t have to be on wheels a trolley jack would move it as well .They would have to be of supreme quality, so as not to become seized through lack of use. They rarely behave the way you'd expect.
As long as they get used they'll be ok. When an item like this lies dormant for long periods, they seize, unless they are of supreme quality. One or more of those dormant castors will likely become troublesome, making the whole wheeled thing a problem.Built a bar on castors , wheeled it round the garden for years without problem .Doesn’t have to be on wheels a trolley jack would move it as well .
Bar was stationary for about 5 years , no problem moving it , well greased bearings.As long as they get used they'll be ok. When an item like this lies dormant for long periods, they seize, unless they are of supreme quality. One or more of those dormant castors will likely become troublesome, making the whole wheeled thing a problem.
Accessible? Sensible.well greased bearings.
