Moved into property and the bathroom radiator has what looks like a fair bit of rust on it. Is it salvageable or do I need a new one?
The radiator doesnt know what is heating the water that runs through it, the dual fuel mentioned in that add means you can if you want add a small electric heater to the rail so it can be turned on in the summer without running the heating, this is completely optional and the rad will run exactly the same as the existing without the electric heaterThanks both. From what I can tell it's not dual, only gas.
As long as the inhibitor is up to scratch so it should be OK on the inside, it wouldn't be a big job to clean up the rusty bits and give it coat of Hammerite. Like new!Moved into property and the bathroom radiator has what looks like a fair bit of rust on it. Is it salvageable or do I need a new one?
In theory yes, but it would take a long time, appearance is more of a problem. If you clean off loose paint and rust and repaint it will be OK. I haven't used Hammerite for years but it used to claim you could apply it firm rust. Probably does. Worked OK on cars!Does this kind of corrosion cause a leak eventually?
Thanks. How exactly do you check the inhibitor?In theory yes, but it would take a long time, appearance is more of a problem. If you clean off loose paint and rust and repaint it will be OK. I haven't used Hammerite for years but it used to claim you could apply it firm rust. Probably does. Worked OK on cars!
Check on the inhibitor, internal corrosion more of an issue.
Take a sample of the system water, about 50ml in a jam jar or similar. If you have a Magnaclean or similar that's the easiest place to take a sample, otherwise from a rad bleed valve or something.Thanks. How exactly do you check the inhibitor?
