I'm going to replace the 18mm floorboards in my flat with 18mm plywood sheets, and I only really need a mini circular saw to cut through the floorboards, but there's a deal on at the moment for the Worx WX437 XL 800W Compact Circular Saw (42.5mm max cutting depth) with three blades for £59.99, or I could get the Worx WX531 18V (same power as a 500W corded, 41mm max cutting depth) with three blades, 2Ah battery, charger and case for £99.99.
Are these both good quality tools?
Although I only need to cut 18mm deep for this job, it might come in handy being able to cut deeper for other jobs in future (not that I have any particular jobs in mind). Would it be any easier or safer cutting the floorboards with a mini circular saw? If not, I can't see any reason to get one of those rather than the bigger saws.
I probably don't need a cordless one. I can switch off the power to everywhere but the kitchen (I won't be replacing the floorboards in that room) and run an extension lead from there to avoid any risk of electrocution if I accidentally cut through a cable under the floorboards (which shouldn't happen anyway if I set it to the correct depth). However, I was wondering if people with experience doing this have found it's a lot easier doing it with a cordless tool, without any cables to get in the way, or whether the battery runs out too quickly and just makes the job harder?
I have several Einhell cordless tools (drill, impact driver, multitool) and a couple of batteries for those, so if I got the Worx cordless it would be a bit annoying having to use another charger for that and not being able to use the Einhell batteries, but the Einhell TE-CS 18/89 Li 18v Mini Cordless Circular Saw 89mm would cost me about £100, without any batteries, spare blades or case, so it doesn't really make sense to buy that (the bare Einhell TE-CS 18/150 cordless 150mm (max depth 48mm) is a bit cheaper at £85, but still a poor deal compared to the Worx cordless package for £100.)
