Don't thank us yet, we need to know it still works!Many thanks. You've probably saved me quite a few quid. Cheers
Hopefully once the thermostat cable is fully removed, that will give you a bit more breathing space within the box.Ohhh.. one further thing perhaps.... Is there any way I can get some bigger box/FCU such that I might be able to get all the cables back in a little easier?
Since there’s possibly no play in the wires/cables for a wiring center, I wonder if there’d be enough play for a double pattress box?https://www.toolstation.com/axiom-p...VGMftCh2iBQVKEAQYASABEgJ6nvD_BwE&gclsrc=aw.ds with a blanking plate on the other side? If not, then, maybe a deep pattress box or a spacer as per @RandomGrinch?How would I go about incorporating a wiring centre box along with the FCU since the cables have all been cut just to fit into the FCU? Can you point me in the right direction regarding what to buy? Thanks
But now I see that your thermostat is a Danfoss RET230L and has been rebranded by Hep2O, could this actually be a standalone thermostat for the underfloor heating?PS... I think the other incoming wires at the top right of the FCU are something to do with the kitchen underfloor heating
Oh dear, sorry about thatYikes... Linking up the black wire didn't work.. The boiler won't kick in even on manual.
Hi there.. I've managed to get back to the house briefly and have spent longer belling out the wires. I was wrong about the above Brown wire in the thermostat. It's actually linked to the call for heat (CH On) in the timer switch.So…I’ve just been back to the house and the cable from the thermostat to the FCU is wired thus:
- Black wire (sheathed blue) at Neutral in the Thermostat goes to Black (sheathed blue) into the FCU load.
- Brown wire at Live in the Thermostat goes to Brown FCU load.
- The Grey wire (sheathed brown) at the thermostat goes to the chocolate block (in the FCU) connection to the black wire that goes to the boiler.
Great, this connection?I was wrong about the above Brown wire in the thermostat. It's actually linked to the call for heat (CH On) in the timer switch.
Great, this connection? I think so yes, although the various chocolate blocks have now been moved around to get a better look at things.
If so, that's more like it!
All you should need would be to link this terminal block, and the black wire to the boiler
A slight note of caution though.
I still would have expected the boiler to fire up when you connected the black wire to the FCU L earlier on.
This baffled me last time too. I'll try again soon as well as carrying out your above suggestion too. I'm in no rush since the internet is unlikely to be back on in the house for another week or so, henvce no point in putting the new Hive in.
I'll get back to you one day soon... Meanwhile, thanks again.My only overall concern is doing any damage to the boiler here with the wrong connections.
We will wait and see.
