Hello there
Can expert help me with the problem of unvented hot water( mega flow) with two expansion valves and pressure gauge losing pressure only during winter when I turn on the central heating.
I have got gas boiler Worcester installed.
I could see two radiators always have gas or no water when I bleed .
I then top up pressure to one and half bar and then bleed radiator and the check pressure and start central heating.after every two days the pressure goes to zero. When I come abs check radiators ( only two) either gas or no water while bleeding so i topup
And cycle begins.
There is no leak on ceiling or floor.
On gas engineer able to
Solve . Should I run sealant in hot water cylinders or leak Detector ?
Please help
And cycle begins.
Please help
