Does this sound like delayed ignition?
28 Oct 2023
I got a brand new Worcester Bosch Greenstar 27Ri gas boiler installed in May and haven’t had any issues with it actually working, except since we started using it regularly we’ve noticed it seems to make a loud noise when igniting (I wouldn’t say like a bang but more like just a loud vibration) only when it’s not been on for a while. I took some videos of it happening when stood next to the flue (boiler is in our garage, adjacent to the house). Every time it switches on it sounds like there’s a ticking/ignition sound as well. Thing is I recently had a Gas Safe engineer - who wasn’t even the same one who installed the boiler - look at our whole system and put new lagging around the boiler so I’d be surprised there’s any issue, but this doesn’t seem normal to me even as a layman, so I’d really appreciate any advice. I’ve uploaded a video to YouTube that probably best shows the issue, taken in the morning yesterday after the boiler had been left off overnight:
Hard to hear anything other than birds tweeting and a slight grumble. Only installed in May then it’ll be under warranty - contact your installer or failing that call WorcesterBosch, if you’re concerned.
its struggling to light, bad gas mix, low gas pressure, blocked condensate all possible causes.
might be a sticky governor on the gas meter. you need your installer back.
Even gas line to boiler blocked perhaps?
Is the Benchmark filled in and what is the inlet working pressure5. ( bet it says 20mb :ROFLMAO: If the figure is indeed noted)
Apologies for late reply; I’ve been unwell. Many thanks for the replies to my original message.
I had the installer round this morning and he cleaned the system but now says the only thing he can think of is the gas pipe: it’s 15mm and hasn’t been upgraded and he didn’t upgrade it. Can that cause this behaviour from the boiler and should I not be using it if it’s unsafe? The boiler only seems to do this when it’s not been on all day or overnight; otherwise it’s fine.
The boiler is not very far from the gas meter: the boiler itself is in the garage and the meter is about 2m away from it.
I’m getting the feeling I shouldn’t have used this installer, but I’m a total layman when it comes to boilers so please don’t judge me too harshly.
If that’s true then great, but can’t they invalidate my whole warranty?
