Hello everyone. Sorry I couldn't find any category to post this on, so I'm posting in the General DIY category.
We've got a Dunsley Highlander 5 Slimline stove (multifuel) which has been working great for the last 5 years. However over the last couple of weeks, the stove has been struggling to light up properly with flames going out very quickly and when it lights up the flames are really fast and wood burns quickly. So I got the chimney/flue checked - The flue is fine and clear with no soot.
So I checked online and found that the issue could be either the rope or handle.
The rope looked reasonably okay, so the next thing I did was to try and tighten the handle nut in the hope that it would close the door and press the rope tightly.
However whilst trying to do this, I've made matters worse as I've accidently damaged the rope and the handle. The rope is now ripped and the handle just spins. I also cannot open the nut in order to remove the handle as it's jammed.
I know I can easily replace the rope by buying a rope kit, but can you please give me any advise on what to do with the handle which I'm struggling to remove or repair?
We're desperate because our living room is freezing cold without this.
Here's the stove description and a photo of what the stove and handle exactly look like:-
www.greenviewheating.com
Thank you.
Dunsley Highlander 5 Enviro-burn Solo Slimline - Greenview Fireplaces & Stoves
Fitted with Airwash Technology Heat Output of 5kW Efficiency 79.3%
Thank you.
