TO a ceiling rose? Why would anhyone do that?The flex could be running from the socket …..
I presume you mean your previous post?See my next post
I considered that possibility, but it would seem unlikely. They would only have had to increase the length of the trunking by about 1 cm for it to reach the ceiling, where there is actually a hole (which has not been 'made good' - see photo) - and it's very unlikely that, in that position, it was a pre-existing rose which they used as a 'grommet'. In any event, that wouldn't explain the use of flex - would a 'proper electrician' use flex to wire a permanent socket?The ceiling rose could simply a neat way to conceal the cable entry or exit from the ceiling. It may not be connected at all
I don;'t know about "the only real question", but ...I suppose the only real question is 'Did you report your concerns to the hotel manager, or do you consider that posting the picture for a lot of strangers on the internet is more useful?'.
It could have been done in all sorts of ways, but what I appear to be seeing is not one of the possibilities I would have expected.If it was from a socket circuit surely it would have a box and blank plate with a spout and yt2 from that.
It's not my wish to 'name' the place, particularly given that we';re not totally sure of what is going on in that wiring.The Bear in Havant?
Given all that we have heard from our 'absent friend' about ''vacuum cleaners in lofts', I though this was rather interesting - because I can't really think of any reason why they would have installed a socket in that location other than for vacuum cleaners or suchlike!
None of those. Immediately adjacent to outside doors (just about visible in photo about 12 inches to left of socket), usually always closed, but which serve as an 'emergency exit', and as far as it could possibly be from any places where items such as you mention would/could credibly be.Lots of possibilities, in a restaurant. Till, point of sale thingummy, booking PC, hot plate.
Flex is as valid as any other cable. Regs allow its use as fixed wiring.would a 'proper electrician' use flex to wire a permanent socket?
