- Joined
- 17 Aug 2010
- Messages
- 2,888
- Reaction score
- 506
- Country
They still sell ones with two output sockets and a bulb holder in home depot.I still have a few of those Y-type bayonet splitters,
Indeed, we all go mad in earthing and bonding to the nth degree as a matter of safety and quite rightly too.In fact (maybe 'ironcally'), in the event of fraying leaving (just) an L conductor exposed, the risk of electric shock will be greater if the iron actually IS earthed!
Exactly, there is always a balance to be struck. In most cases, earthing things will, indeed, 'on balance' be the safer option, but 'unnecessary' earthing can easily have the reverse effect. For example, some people might feel that to earth an outer touchable conductive part of a Class II item is a good (and, they think, 'harmless') idea, as a 'belt and braces' measure in case the 'double insulation' were to totally 'fail'. However, as EFLI frequently punts out, 'on balance' such 'unnecessary' earthing actually creates more of a potential hazard than it protects against.Indeed, we all go mad in earthing and bonding to the nth degree as a matter of safety and quite rightly too. .... However in some conditions it can actually cause a reasonably "safer" situation to become far more dangerous.
Very true. If supplies were not earth-referenced (i.e. if they were 'floating'), then everyone would be safer and 'earthing' would be an irrelevant concept. However, I imagine that it was decided that there was no way one could guarantee an absence of an 'incidental' earthing of one side of the supply, so better to 'pre-empt' that by deliberately earthing one side? Or was there some other reason - I just don't know?If we could live in an all insulated world it could be a safer place.
From my cellar .... one light bulb (no argument about the word back in those daysThey still sell ones with two output sockets and a bulb holder in home depot.
Quite so.Agreed, ... Incidental Earthing and Deliberate Earthing puts us in the mode of needing Earthing . ... As you rightly say, necessary earthing is fine but unnecessary earthing can increase danger. ... If double insulation etc is of a reliable quality then great.
Welcome to the forum.What a horrible setup that is though here in Malaysia no one would give it a second glance. In the UK
EICRs are undertaken with reference to the current version of the regs (BS7671) (whether one regards those regs as 'wrong' or notIn the UK I would expect an EICR to reject a double socket fed by a ceiling rose wherever it was supplied from. Whatever the regs say a double socket on a lighting circuit is clearly wrong. Think two cleaners plugging vacuums at the same time.
Agreed, indeed another problem arises because the earth itself is not very conductive per unit part .However, even if that had been done, there would still have been a big problem 'outdoors' - since there is necessarily plenty of 'earth' there!
I wonder if we refered to them as X circuits (x representing the fuse or breaker nominal rating) might be more helpful?
We could.We could stop calling them lighting citcuits.
